Hi
We’ve just taken over some old MT 3.11 systems running on PC Engines boards.
We normally run a checkin script using fetch to let us know that the units are working fine, however it appears that /tool fetch keep-results=no is no available on 3.11 so it writes a file each time the script is ran.
Is there any workaround to not saving the results - i suppose I could just delete the file after each checkin but it seems wasteful.
