i am using /tool fetch to send some data over the internet via https.
Well, our https server is configured just to use TLS 1.0, TLS 1.1 and TLS 1.2. SSL1,2 and 3 is forbitten. There are a lot of side chanel vulnerable for that. Also we forbit RC4 too avoid BEAST attacks and we disabled compression.
I figured out that when i enable SSL3 /tool fetch is running. When i am disabling SSL3, i am getting a certificate handshake error.
Why does /tool fetch does not support TLS?
In which router os version it is planed to add TLS Support for /tool fetch?
