Under graphing settings I have this.
“/ tool graphing queue
add simple-queue=all allow-address=0.0.0.0/0 store-on-disk=yes allow-target=yes disabled=no”
And you can set it to store every 5 minutes, hour or 24 hours. If its set for every 24 hours is there anyway to tell it to record on shutdown as well? If you go to system reboot I would like it to record before it reboots.
Reason being is to conserve flash life I want to set it to 24 hours but I do not want to lose 24 hours worth everytime I reboot.
Matthew
