tool suggestion
Please add:
1-Ping IP scanner, where you can define an ip range and ping for host in that range…
2-access to the embedded browser, so we could remotly web manage stuff …
thanks
tool ipscan might do some of that address range checking you are looking for.
If you need to remotely manage something with a web browser, you can set the MT up as a pptp server with the pptp proxy arp on, and you can have local access to the remote LAN from your pptp client workstation.
