I create an script to generate a simple configuration for mikrotik. This script create firewall input, forward and output rules, access list (ACL) for access to mikrotik, dns primary and secondary, identity name.
It’s on alpha step, you can use it. I use this like template.
you can try it at:
http://www.ping.net.ar/mikrotik
Pse. send me suggestion and correction.
Regards
Maximliano Dobladez
Intercity SRL
Rio Cuarto-Argentina
