Hi all.
Dude ver 4b3 running as Administrator and UAC, firewalls etc disabled.
Working:
Ping
SNMP Walk
FTP
Not Working:
Traceroute
Telnet
SSH tool:
Created as: C:"Program Files (x86)"\PuTTY\putty.exe [Device.AddressesColumn]
If i paste this into cmd window it works btw.
What gives.
Canât find relevant log files to assist.
Anybody.
Kind regards.
Telnet was removed from windows starting at vista⌠http://www.barkingseal.com/2011/04/o-telnet-telnet-wherefore-art-thou-telnet/.
Maybe change ssh to
âC:\Program Files (x86)\PuTTY\putty.exeâ [Device.Name]
or
C:\Progra~1\Putty\putty.exe [Device.Name]
or install putty in a folder that doesnât contain space or more than 8 chars.
C:\Putty\putty.exe [Device.Name]
Does traceroute work from a cmd prompt?
HTH,
Lebowski
Thank you Lebowski! You helped another person with the same problem! It works great now.
-NerdTool
