Hi! I use Traffic Monitor to report abnormal traffic flow directly from switch/router but I see that maximum threshold is limited to 4200Mbit/s. Why? Can it be fixed in next RouterOS?
Wrong place to ask, since this is a user forum. You probably need to submit a support ticket if you want any resolution.
I have no authoritative answer, only a guess.
My guess is that it is a 32 bit unsigned value. 2^32 is 4294967296
And, what hardware is this on? i.e. Some devices run 32bit RouterOS
It’s new CRS-326-24S+2Q with the latest RouterOS and its already has 64 bit counters so I guess is not depends on CPU architecture.
Yup, I was thinking it was like counter problem on 32bit RouterOS too. If counters are 64-bit, agree traffic monitor should be too.
I'd report it as a bug at Log into Atlassian - Support
