Top Up Credit unit
How can i configure my router to give avenue to client to Top UP their credit unit before it elapse?
Currently it is not possible to do it automatically, you have to renew it or run scripts, which will assign new limitations.
What am really looking at for instance, a customer comes to my internet cafe and buy credit unit of 30minutes. He begins his downloading of file that could not finish within that 30minutes. Now if he allow the 30minutes to finish, his download will automatically close or time out. Which means, if he buy another credit unit he has to start afresh which is not encouraging.
So what i want is to alert them by pop up a message once the time is below 5minutes and give them the opportunity to add additional credit unit to avoid the previous one from timing out.
Thanks in anticipation.
If you will change (Change of Authorization) settings of the client, then user should not be disconnected.
Hello sir, please can you throw more light on this your response. I am having the same challenge here at my site and your response will be very helpful.
Efosa
When HotSpot user settings are changed on User Manager, and User Manager sends these changes by CoA packet, HotSpot user is not disconnected, but new settings are applied for it.
This reply certainly got me more confused than the first one…Please explain in simple terms what can or should be done to correct this issue if any??
I do not think this is issue anyway.
Do you use CoA (change of authorization) between your HotSpot and User-Manager?
Hi am not clear on your question and i happen not to know the meaning of CoA at this time…Pardon me..but i will await your solution to this problem i have.
Please, describe your problem in details. Create different post, if it is different from original author’s topic.
Hi have posted a new post with same issues i had earlier…see the post
‘‘top up tickets when using usermanager’’
hi,
i observed that when a ticket is created from usermanager for a client to browse with, and that ticket is exhausted when a user is doing a large download, by the time he logs in again with another ticket, he has to start his download all over again. Is it not possible to combine or add tickets to an already being used ticket to prevent users from starting their work all over again?
please speak
Yes, it is correct.
If you change settings for HotSpot user and you do not want that user is disconnected, then CoA should be used.
RADIUS server will sent new settings for client, but it will not be disconnected.
From RADIUS client manual,
http://wiki.mikrotik.com/wiki/RADIUS_Client
RADIUS disconnect and Change of Authorization (according to RFC3576) are supported as well. These attributes may be changed by a CoA request from the RADIUS server:
Mikrotik-Group
Mikrotik-Recv-Limit
Mikrotik-Xmit-Limit
Mikrotik-Rate-Limit
Ascend-Data-Rate (only if Mikrotik-Rate-Limit is not present)
Ascend-XMit-Rate (only if Mikrotik-Rate-Limit is not present)
Mikrotik-Mark-Id
Filter-Id
Mikrotik-Advertise-Url
Mikrotik-Advertise-Interval
Session-Timeout
Idle-Timeout
Port-Limit
Note that it is not possible to change IP address, pool or routes that way - for such changes a user must be disconnected first.
It is so disheartening that you cant come up with yet a simple explanation as to how to get the issue solved, If i persistently do not understand you, you should know its not deliberate. You may wish to just put in simple terms what i should do to solve the problem..Its too late in the day anyway to let go of mikrotik.. the least you can do is to let someone else respond to this issue i have and make my day.
Can someone help us out of these serious issue?
Am really losing my hotspot client because their download terminate before they get additional browsing time.
help please
firewallrule,
do you CoA on between router and RADIUS server or not?
Like sergejs said, there’s currently no way in routeros for a client to top up their credit themselves before it runs out.
If you use Mikrotik usermanager + hotspot for your AAA (assigning credit limits etc) then two things you need to do:
  • alert the client that credit time-limit is almost up, and then
  • renew the clients credit time-limit before it runs out (either manually or via scripts).
For the first, someone recently wrote scripts that you can customize to get that done for you; you’ll have to search it out on the forum.
For the second, you need to enable CoA (change of authorization) on a port of your choosing in web interface of your usermanager (Router section) as well as set the same port for incoming in the Radius section of your hotspot router
/radius incoming set port=xxxx accept=yes
. This ensures that any credit added to the client is effected ‘realtime’, before the first credit runs out. Mikrotik usermanager uses ‘profiles’ to assign time-limits or volume-limits to clients. The only way you can extend the clients credit is by adding another time-limited (e.g 10min) profile to the client’s original (e.g 30min) profile before the first elapses. Manually or by scripts.
Sounds a bit cumbersome but i’m sure Mikrotik will come up with a more elegant method in the future.
Thanks for your clear contributions! U know this forum is very large and searching for a piece of script can difficult expecially without an idea of when it was posted and who posted it, If you have complete idea, do help pls. So many people are interested in this. This topic has been raised long ago but thank God solution is o the way. So we are waiting and searching as well.
Sorry, I know very little about scripting.
This links to some things you can try out: http://forum.mikrotik.com/viewtopic.php?f=10&t=35798&start=0&hilit=I+need+an+alert+on+my+Hotspot
It’s supposed to alert the client before time-limit elapses.
Pls help, on the web interface of the usermanager, i cant find anywhere to enable Change of Authorization.
I have attached a screen print of the router section via web interface.
router section.docx (93.2 KB)
router section.pdf (66.7 KB)
