Getting info from my Mik via ssh:
ssh user@192.168.1.1 '/tool torch interface=ether1 freeze-frame-interval=2 duration=3'
and then dump to local disk.
And there is output, that inconveniet to parse (line parsing with python script), because every time the torch data differs (4 lines with data one time, 2 lines other time)
TX RX TX-PACKETS RX-PACKETS
0bps 0bps 0 0
0bps 0bps 0 0
164.2kbps 757.9kbps 88 196
153.1kbps 697.1kbps 85 183
To parse dump file i need concrete line numbers. Also, i have experimented with params “freeze-frame-interval” and “duration” (even without them) - no solution.
Could you give some advise how to make what i need?
If i chose worng topic - sorry. Thanks a lot!
