Torch stoped working
Does anyone have an idea why my torch could stop working? When I go to it with winbox and click Start it just doesn’t work. When I run it from console the router hangs :open_mouth:
It worked before :frowning: :blush:
You should upgrade to the latest version, to 2.8.28 or 2.9rc7.
And if you problem still exists, contact support@mikrotik.com with attached support output file from your router.
had the same problem with torch not working in 2.8.24 suddenly. Upgraded to 2.8.28 but still have to try torch ill post what i get.
Reinstall did the trick :wink:
