Torch Tool
on one of the interfaces in Mikrotik I have increased network traffic, when I choose the tool Torch ,Tx rate in all displayed connections is 0 bytes and Rx rate shows the flows, does anyone know to explain why this happens and if I’m wrong somewhere?
selected parameters within the Torch tool:
src address
dst adress
port
protocol
Winbox(64bit) v6.47.1
RB3011UiAS
What is the protocol ?
protocols and ports are left to ANY, deafult option in Torch Tool
Is the Interface you try to monitor, Hardware Offloaded ?
If that’s the case, packets processed by a Hardware Offloaded Bridge will not be visible through Torch, except some unicast, multicast and broadcast traffic …
Yes, this interface is hardware offloaded, thanks
Ok… Then that’s the reason…
You can also take a look here :
https://help.mikrotik.com/docs/display/ROS/Torch#:~:text=MikroTik%20Torch%20is%20a%20real,dropped%20by%20your%20Firewall%20rules.
