hi guys
iam new at the server world and i have a big problem
iam using p2p download in all of my work
and after i setup the server i found out that i can’t download any torrent
some friend told me to disable the torrent block role and i did
and the torrent worked again but the problem is the download speed is so looooow
i have 2mbit line
the download start good at first and after 1 minuet it drubs so low and keep that way?
what is wrong plz
and can u tell me how to ipen a port for the torrent
thanx for ur time
cheers
DannyZ
2
and server u use? we should discover ir on our crystal balls?
uldis
3
Try to enable the UPNP on the router if you are in the private network and configure the torrent client to use UPNP.
DannyZ
4
if it’s not solution, try to make Nat rulle with masquarade action.
thanx uldis
my router is tp link 8840 and i have an open port for utorrent on it
and the upnp are used in utorrent
but i allows get the red lite in the port checker in utorrent
DannyZ
8
What Firewall rules u have @ Filter Rules and NAT? And are u sure about that your ISP/WISP are not queuing p2p trafic by priorety?
BS85
9
Try a forum that deals with TP-Link hardware.
