Hey all,
I’ve been trawling through the forum and I think I need to pose a question. We’ve just started testing VOIP in our office and are hoping to migrate our main lines to a hosted PABX solution. For the first week it ran quite well, now it’s started to go pear shaped. I believe it may be an issues with our up stream provider, but I want to do everything I can to eliminate it being us. Our outbound pipe is getting quite full, but I have QOS turned right up for voip and am not seeing any packets queuing up. The problem is the call keeps dropping out. We have a client using the same up stream provider and they are having the same problem, they have 1000% less traffic on their network than ours.
I added the following rules http://wiki.slfree.net/index.php/QoS_for_VOIP_in_Mikrotik to our routers. I see packets being marked and going through, but still have the dropout issue. I don’t see any queued traffic.
A few questions.
On the other site we have ROS 3.14 installed, I can’t seem to find a way to isolate the DSCP tos values for the queue up there (although there is little traffic, I want to do all I can to eliminate our side of the equation as being at fault.). I tried wireshark and it doesn’t pickup any sip calls or rtp traffic when calling. (I also plugged in via hub)
How much traffic should a single voip call require? I see about 40 - 70kbps, stabilising on 50kbps
How else can I test voip / qos. What other tool can I put in place / work with to fine tune and get the most out of it.
I’m seeing a lot of SIP traffic overhead, I though rtp should be the bulk of it. i.e. voip-sip 40MiB up and down, voip-rtp 18.3MiB.
I look forward to some suggestions, feel free to point me towards reading material I might of missed.
