Total bandwith
hello, i’m using Mikrotik 2.9.6 i have 10 clients with simple qeues for each one (8000/56000) and my total bandwidh is 128/512 but there is a problem when 8 clients be online in same times they take all bandwidth so there is any way to keep simple qeues but give all clients only 50% from total bandwidh?
thank u
I think the uplink traffic won’t be a problem. You still have enough pipe for 10 users.
For downlink, use the queue tree. You can make a parent queue, so the router knows that you only have 512000 speed. Put all other queue inside the parent queue. Put limit-at as 51200 and max-limit as 56000.
can u explain by an example plz.
thank u
see this:
http://wiki.mikrotik.com/wiki/PCQ_Examples
