Thanks for any help. I have tried both the Beta and release version and have spent an hour or thereabouts…
I Cannot seem to figure out how to get a network map?
Is it that you have to create a blank map of graphics first? And then somehow apply the addresses?
That cant be right..
Any simple how to is appreciated.
I drag Network Map/Local into a pane
I select Network Maps/Local
Select Discover
I choose layout map after discovery complete
I see it scan
I can see the devices under Devices/Mac Mappings (i am not getting any info on the type of device however)
Thanks again.
James
