By inserting the OID for connected clients in the Appearance tab I can see how many clients are currently connected to each Cisco AP - is there a way to automagically add these numbers and have them shown on the map as the total number of wireless clients?
We have Cisco 350 Access Points and I haven’t been able to display the number of connected client’s nor have I been able to find the correct MIB’s.
What OID do you use?
Do you have the correct Cisco MIB’s?
In Appearance → Label → Insert OID I use [oid(“iso.org.dod.internet.private.enterprises.9.9.273.1.1.2.1.1.1”)]
This works for IOS 12.3(2)JA
I don’t use any other MIBS than what the Dude is shipped with.
HTH
Ah, thanks!
Works on my Cisco 350 that I converted from VXWorks to IOS… I should upgrade all of them to IOS anyways.
