Webfig has been great use for remote wireless access to RouterOS with smartphones, you know you have it all in your pocket and with some touches you get things done. It’s really not that easy to type command lines on rooftops or towers, but using Webfig cures that all. But it has some limitations of its own. Particularly with double-click when you want to edit an entry. You can do it on a PC, it’s pretty straightforward just double-click. But double-clicking on a touchscreen smartphone browser doesn’t do the trick (at least not in most of the cases).
I think it would be easier to implement one-click on the Webfig interface, because after all it’s not that Webfig allows you to SELECT, so double-click is not needed. Or it could have a E (edit) box right after the D (disable) one. It’s a pretty easy solution. Besides this Webfig’s been great.
That would make it touch-friendly.
Please consider this as a recommendation, not a request ![]()
