TP-Link 851ND PCI card
Helloo,Did anybody know does mikrotik 5.00 x86 support pci wireless card tp link 851nd.can i set it up to work only with one RP-SMA output.One Sector antena?Thanks.
It should do.
Steven
i buy this card and its work very good :slight_smile:. i tested it with AP bridge on one Anntena.
tp link 851nd not work for me on 5.20 mikrotik version plz help me if there is any drive to support then share it plz
MikroTik is working driver less or better in another direction and there would be no drivers for the customers
to install or compile in. Contact the MikroTik support will be the only way to get this card be recognized and
sorted by a driver.
