Is Tp Link AP compatible with Mikrotik RouterBoard 4.16 ? The following model?
(2.4GHz High Power Wireless Outdoor CPE TL-WA5210G)
Arman
Arman
There should not be any problem, as TP Link is compatible with 802.11b/g.
thanks for your reply…
but how to configure it through winbox please explain …
Arman
what exactly do you want to configure? the routerboard needs to be set to “station” mode, and to the same frequency as the TPlink AP. It also needs to be set to the same SSID as the AP.
i am installing Wireless AP 1st Time dont know how to do ? can i control the TP link AP thorugh Winbox after installing like mikrotik AP’s?
Arman
of course not, it’s not a mikrotik product. why do you need a TP link AP, it’s inferior to Mikrotik products. It would make sense if you would use the RouterBOARD for the AP as well.
if i will get mikrotik product will it work like what i want ?
It depends on what you want. What are your requirements?
my requirement is internet access to users via wireless from my site to 360 diagonal just and i can control the wireless ap through winbox?
Arman
simple configure tp-link Ap.
and r u from pakistan.
Use ur Mikrotik as an AP and Configure ur TPLINK 5210 as client or in bridge and u can deliver internet to ur users. No u cannot use ur TPLINK 5210 thru winbox as it doesnot have Mikrotik RouterOS
Yes Usman I am from pakistan
i am also from pakistan (lahore) if u need help contact me @ usman_tahir880@yahoo.com
hey usman i am from rwp !! ![]()
