TR-069 fail with any HTTPS
In following example simple tr069-client without any certificate checks
/tr069-client
set acs-url=https://example.com enabled=yes password=test \
    periodic-inform-interval=1m username=test
example.com - have valid asterisk certificate from DigiCert. I also tried Letsencrypt one with same results .
It is NOT self-signed but i constantly get :
“SSL: handshake failed: self signed certificate in certificate chain (6)”
With HTTP it is working fine.
Can you please fix it. It will be also good to remove from mikrotik wiki genieacs. Because it is outdated and not supported in reality by mikrotik. In current time freeacs have much better support.
