tr069-client - initial implementation (as separate package)
Hi Mikrotik,
Nice to see these addon. I’ve just check it in my ACS and it seems to work.
Thanks and continue developing these package.
Where can i see it ?
It is in the 6.38rc24 changelog.
You can find it in the all_packages zip for the intended platform.
Any free server that supports mikrotik as of now ??
You can do it with freeACS or GenieACS (and surely much more)
WOW!
Just tested, this is great!!!
Tested and working great, this and genieACS, its amazing
Our TR-client should work with any compliant server, our Data-model is based on TR-181 Issue 2.
Just trying this out now - where in the model are PPPoE client interfaces exposed? I don’t see a way of setting these. We need to be able to configure PPPoE username and password
Currently not yet implemented, you have use a script, but we will add support for directly setting it.
OK.. thanks.. we need this feature to roll it out - any ETA on this enhancement? Could this come in another 6.38rcXX version?
Just adding my support for pppoe, this is a requirement
Any word on adding PPPoE username/password setting to TR-069?
6.38 has PPPoE support
That’s great to hear - Thanks!
