I had successfully got a freeacs server online and working and doing what i needed. Was just not real impress with the GUI and the interaction.
I now have got a Genieacs online and working. However I can not get it to do what I want. I am trying to disable a port. When I do it the the gui i get and cmwp.9002 error code. To make sure it worked at all I tried to rename the ssid and this worked. So i belive my box is setup correctly. I just can get it to disable a port.
Actually when looking at it all i see is interface 1. I do not see my vpn clinet connection as an interface which is the one i want to disable/enable
