TR69 on RouterOS
Hello Guys,
Kindly assist me in enabling the TR69 feature on my Mikrotik. Is there a script I should run? My Mikrotik is
Model: 750
Firmware Version: 3.02.
Any assist will be greatly appreciated.
Point of correction, I have upgraded to version 6.37.1. Please assist…
https://wiki.mikrotik.com/wiki/Manual:TR069-client
If you are testing tr069, update to the current 6.40 release candidate version and then download the ‘all packages’ zip file for 6.40rc for your platform, in there you will find the tr069 client. Add it to the root /files folder on the router and reboot. You will then see the TR069 option in winbox or webfig.
If in production you can run 6.39.1 but then TR069 is only available for configuration from the command line.
Thank you @mducharme. Muchas gracias!
