traceroute between internal routers fails on in between host
Test my network
I noted that an in-between router 10.100.2.5 drops 100%.
Yet I can ping just fine.
[sjwrick@main] /tool traceroute 10.100.17.1
ADDRESS LOSS SENT LAST AVG BEST WORST STD-DEV STATUS
1 10.100.0.4 0% 10 0.6ms 0.6 0.5 0.9 0.1
2 100% 10 timeout
3 10.100.17.1 0% 9 14.9ms 12.2 5.5 25.7 6
[rboucher@CloudCore3] > ping 10.100.2.5
SEQ HOST SIZE TTL TIME STATUS
0 10.100.2.5 56 63 3ms
1 10.100.2.5 56 63 10ms
sent=2 received=2 packet-loss=0% min-rtt=3ms avg-rtt=6ms max-rtt=10ms
What would be causing this?
Check the firewall. Traceroute uses UDP (on Linux) to do its magic. Maybe the router’s firewall is dropping them. The ping is something completely different, and is getting through.
https://en.wikipedia.org/wiki/Traceroute#Implementation
