Traffic Balancing Issue in Bonding
I am facing an issue with traffic balance in bonding member port, Bonding between Mikrotik to Huawei switch using 2 ports.
For load balancing I execute a command load-balance src-dst-mac in Huawei ether trunk but problem is not solved.
The service is running in Mikrotik for PPPoE.
I am requesting, Please provide the solution for load balance.
A single PPPoE session always uses same SRC and DST MAC address pair (reversed in opposite direction), hence Tx hash policy always selects the same physical link (bond member). The only way to see traffic move to another physical link is if the active one fails.
Please suggest me a smooth suggestion what should I take which will be improve to load balance on the both physical port, Currently one port getting 700Mbps other 200Mbps and both physical ports are in single bonding
Dear Support,
Please suggest the next what should I do.
If you really want reply from official Miktotik support, open a ticket. https://mikrotik.com/support
This is a community forum and MT staff doesn’t read all of it …
