Hi …
Most NV2 setups are PTP or PMP and biggest traffic exists between AP => CPEs.
Now - what to expect from NV2 considering traffic between CPEs?.
I have a 900MHz setup (5MHz channel) where the AP is at the middle of the path but GW for internet is one “CPE”. There’s a second CPE at the end of the path.
This AP is bridged to another card just to serve 3 customers on 2.4 just for ease.
But most traffic must be from one 900MHz CPE to another.
Using Nstreme sometimes peak 2,5Mbps Internet CPE => Remote CPE on rush hours. If I switch to NV2, despite of more or less the same connection speeds traffic drops to 50% between them.
If I sink some bandwidht with some 2.4 AP client, I have 2.5Mbps peak again (of course only at the path AP<>GW CPE). This means that using NV2 or Nstreme the max speed is “ok” between AP and GW CPE. But NV2 seems unable to “store and forward” traffic from GW CPE to end point CPE the same way Nstreme is.
The way NV2 was conceived … traffic between CPEs can have the same performance as traffic between AP => CPEs?
Regards;
