Traffic Calculating
I have some hotspot users on my router and I have a problem in calculating traffic.
I am downloadin a file with 16MB size, but the router calculate just some KBs.
What should I do?
Regards
Hamed
what is your Accounting?
I have this issue on both local hotspot users and radius users.
Sent from my Nexus 6 using Tapatalk
Please see this screenshot.
Just when Torch is running, traffic calculates well.
How do you calculate traffic?
I am not calculate traffic. HotSpot should calculate traffic itself.
In Statistics tab for a local user, I see wrong amount for Bytes In and Bytes Out.
When it is fixed by starting torch, as you say, just turn off Fast Path in IP Settings and it should be OK.
Yes!
Thats right!
Thanks.
Fixed :slight_smile:
