Hi Normis and co
Just want to check if there is a Traffic Flow Counter Wrap bug going around on > 1 Gig interfaces ?
A similar issue has been raised before by forum user Cha0s before http://forum.mikrotik.com/t/traffic-flow-octets-counter-wrap/93289/1 . I suspect I might be hitting the same issue.
Just wanted to check if Mikrotik are still looking into this or if someone has figured out a workaround for this ? Busy investigating my flow software but the issue seems to be present only on flows being exported from Tik devices.
Have tried this on 6.42.12
