Traffic flow crisis that runs through two LANs with one WAN
Hai!
It has been four months i’ve been using mikrotik..i have gain a lot of knowledge and experience along the way..now i have 4 mikrotik routeros running for my clients! :smiley: thank you to mikrotik forum and mikrotik support for assisting me and sharing the knowledge. :smiley:
I would like to post this question to all..
One of my mikrotik routeros is running on two LANs and one WAN. The two LANs reside on different interface. LAN A is assigned to IP address 192.yyy.yyy.1/24; and LAN B is assigned to IP address 10.zzz.zz.1/24 with DHCP enabled.
These are the IP address of the interfaces:
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   192.yyy.yyy.1/24   192.yyy.yyy.0   192.yyy.yyy.255 LAN A
 1   10.xxx.x.xxx/24    10.xxx.x.0      10.xxx.x.255    WAN
 2   10.zzz.zz.1/24     10.zzz.zz.0     10.zzz.zz.255   LAN B
The ip route is:
#     DST-ADDRESS        PREFSRC         G GATEWAY         DISTANCE INTERFACE
 0 ADC 10.xxx.x.0/24      10.xxx.x.xxx                               WAN
 1 ADC 10.zzz.zz.0/24     10.zzz.zz.1                                LAN B
 2 ADC 192.yyy.yyy.0/24   192.yyy.yyy.1                              LAN A
 3 A S 0.0.0.0/0                          r 10.aaa.a.aaa             WAN
I received lots of complains from my clients which use LAN B saying that the internet is slow. When i winbox into the mikrotik, i could see that LAN A is transmitting and receiving in high rate but LAN B is transmitting and receiving very low. I didn’t receive any complaints from clients on LAN A. I use torch to see the realtime traffic flow. This is what i get:
LAN A:
PRO.. TX         RX         TX-PACKETS RX-PACKETS
tcp   947.4kbps  901.9kbps  178        249
LAN B:
tcp   120kbps    3kbps      10         8
I don’t understand why is this happening..i assumed that could be because these two LANs share the same gateway. So i did a routing rule to force LAN A to use gateway 1 while LAN B use gateway 2. I add this ip firewall mangle:
 0   chain=prerouting src-address=10.zzz.zz.0/24 action=mark-routing
     new-routing-mark=net1 passthrough=yes
 1   chain=prerouting src-address=192.yyy.yyy.0/24 action=mark-routing
     new-routing-mark=net2 passthrough=yes
Then the ip route is:
 1 ADC 10.zzz.zz.0/24     10.zzz.zz.z                                LAN B
 2 ADC 192.yyy.yyy.0/24   192.yyy.yyy.y                              LAN A
 4 A S 0.0.0.0/0                          r 10.bbb.b.bbb             WAN
After i did that, LAN B shows trasmitting and receiving much better. And the internet surfing is much faster. However, it didn’t last. After a few minutes..the problem occurs again. I am so confused why is this happening? Could anyone help me please…is there a better solution to this? thank you.
How much bandwidth on the WAN? It’s more than likely the one LAN using all available bandwidth.
Impose some QOS or traffic limits - it will solve the problem if you provide equal amounts of bandwidht to LAN A as well as LAN B on the WAN link.
