I’ve turned on Traffic Flow and sending the flow data to IBM Tivoli Netcool Performance Flow Analyzer. When I look at the data grouped by interface (so I can check my bandwidth usage), the various interfaces show up named as follows:
Exporter IP Address, Interface Name, Flow Version
172.20.10.254, 13@172.20.10.254, NetFlow v9
172.20.10.254, 108@172.20.10.254, NetFlow v9
172.20.10.254, 109@172.20.10.254, NetFlow v9
Is there any way to either:
a) Get the miktrotik to name the interfaces to something more readable (e.g. VLAN103 as opposed to 13@172.20.10.254)?
b) Run a command on the mikrotik to show me which interface is ‘13’, ‘108’, etc.
Or, is this something that the flow analyser software should be handling? I notice that ntop displays them with the same names as the IBM product.
I’d like send he flow data for about a dozen Mikrotik routers to the flow analyser but the interface ‘names’ that show up are confusing things.
