Traffic Flow only TX
I have setup the traffic flow on a CCR router in order to monitor traffic on one interface. I capture a pcap file for testing purposes and i see that it sends samples only for outgoing traffic. Is there any limitation? In my pcap i can see only outgoing traffic.
Thanks in advance.
If you’re using fast path turn that off a and see if it works
I have not the fast path enabled :frowning: Any other solution?
