Equis
January 7, 2007, 9:19am
1
Hello
I am learning about Traffic Flow
I got it saving to mysql
My question is, what if mysql server (netflow collector) stops?
Will Mikrotik Traffic Flow wait or just keep sending data?
Also, what is Unmanaged pkt & bytes?
Also … What is cache entries for?
What are you using to stuff that data into mysql with? I’ve been searching for a decent process to do this.
Sam
Equis
January 7, 2007, 9:53pm
3
inet-lab.naist.jp/measurement/NetFlow2MySQL/ Works vert well
Equis,
Once you have the data in a mysql database what are you using to graphically access that data?
I was looking at maybe playing with http://www.ntop.org/
Equis
January 8, 2007, 2:31am
6
That a good program
Does it store to sql?
I’ll be using mine for pretty much accounting only.
I hell of a lot of data to store tho
I haven’t used it yet, but all the reading i’ve done on it looks alot like it uses RRD and graphs the traffic but doesn’t store to a database. I was just looking for something that does both.
the link is no more available can you provide me the app??
xezen
April 14, 2015, 4:58pm
9
were can i find this app also looking for the same thing to save to mysql
