Traffic flowing only through wlan2, not wlan1
2GHz wlan1 in ap bridge mode
5GHz wlan2 in ap bridge mode
both wlan1 and wlan2 (including ether2-5) are bridged
Clients can successfully connect to both wlans but traffic is only seen on wlan1
Any thoughts why?
add admin-mac=74:4D:28:72:9F:C2 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=2 band=2ghz-b/g/n channel-width=\
    20/40mhz-XX country= default-authentication=no disabled=no \
    distance=indoors frequency=auto frequency-mode=regulatory-domain \
    installation=indoor mode=ap-bridge radio-name=ZZ2Gbase ssid=ZZ2G \
    tx-power-mode=all-rates-fixed wireless-protocol=802.11
set [ find default-name=wlan2 ] antenna-gain=2 country= \
    default-authentication=no disabled=no distance=indoors frequency-mode=\
    regulatory-domain installation=indoor mode=ap-bridge radio-name=\
    ZZ5Gbase ssid=ZZ5G tx-power-mode=all-rates-fixed wireless-protocol=\
    802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=\
    voiwakpoby123 wpa2-pre-shared-key=voiwakpoby123
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE dns-server=192.168.88.1 local-address=192.168.89.1 \
    remote-address=vpn
add bridge=bridge comment=defconf interface=wlan2
/interface l2tp-server server
set ipsec-secret=lalala use-ipsec=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption
/interface wireless access-list
add interface=all signal-range=-85..120 vlan-mode=no-tag
    192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1
    192.168.88.1 netmask=24
set allow-remote-requests=yes servers=192.168.88.1
/ip dns static
/ip firewall address-list
add address=192.168.89.2-192.168.89.255 list=vpn
