i have uplink nic with ip 212.55.89.56 with gateway 212.55.89.55
and downlink nic with ip 82.54.88.98
in the ip routes my default route is dest 0.0.0.0/0 to default gateway 212.55.89.55
uplink is 128 rx and tx and downlink is 512 cir
i run the squid on 82.54.88.98 so all traffic on poort 80 is on downlink
i need now to switch some other traffic to the downlink like p2p and ftp and irc and leave upplink return channel for only msn camera and voice and yahoo cam and voice
in nat my src nat is going to uplink i shull add srcnat on downlink ip ?
pls if somoen has any suggestion or made this before
policy routing is what i think you need, it involves mangle and ip route so read up on there about it. I think you need to route mark all the traffic you want going to the other gateway and then add a new static default route to route traffic with the route mark you have applied.
I think this is what you need, its a little diffcult for me to understand what exactly you want and what your current setup is
that’s what i am doing prerouting for traffic in mangle each with its port and then static routes to the downlink ip i cannot use downlink gateway
in 2.9.6 i am able to put 2 static routes on uplink interface downlink gateway and uplink gateway and each one has prefered sourse for example static router on downlink has gateway 82.19888 and uplink route has 212… both gateways are in my uplink provider location
now on 2.9.10 one static route is marked by As and working and second marked as S and it gives blue color
anyway i am marking packets and doing as you said i ned to add any thing in the masquerade src nat ?
Mikrotik Configuration
Uplink nic 2 ips : 212.55.89.56/29 and 82.54.88.98/29
Downlink NIc Ip : 10.20.30.1 coming from dvb
Users nic PPOE SERVER
ip routes table is
As 0.0.0.0/0 to default gatewy 212.55.89.x at my isp
if i add here a secound route for the downlink ip the route is marked with S only and blue color
if i put the real ip of downlink on downlink interface i cannot see my default downlink gteway at the isp
my main problem i discovered it is with src nat , cz it is thru uplink interface i copied the rule and made one source nat to fiber connection ip
and another one for downlink ip
and i marked all pakets i want to forward to downlink ip
my main question
should i use in the ip route , route all to downlink ip or to downlink gateway at my isp ? i routed all to the downlink gateway and all is working exept the web , when i move the downlink ip from squid even if the port 80 traffic is marked and routed to downlink gateway , the browser send requests to 212.x.x.x.
route table
10 A S 0.0.0.0/0 r 212.98.1x.1x (uplink gateway at isp)
r 82.198.x.1x (downlink gateway at isp)
11 A S 0.0.0.0/0 r 82.198.x.1x mark http
12 A S 0.0.0.0/0 r 212.98.1x.1x mark icmp
13 A S 0.0.0.0/0 r 212.98.1x.1x mark msn
14 A S 0.0.0.0/0 r 82.198.x.1x mark p2p
