Traffic generator over wireless issues
We’ve been trying to run the traffic-generator tool with a pcap file exported from Wireshark and from the internal packet capture option and then try to inject it through the wireless card.
Unfortunately we cant seem to see these packets being sent (we tried capturing them with Wireshark)
Is there a specific configuration that we should use for the wlan interface, or any protocol limitations on the traffic-generator ?
We’re using an RB411GL with RouterOS v6.38.1 (stable)
Thank you very much for your help,
N.
No one tried to use traffic generator with a WiFi daughter card ?
