What could be causing this?
https://www.youtube.com/watch?v=RBOB420gb20&
It doesn’t happen ALL the time, just sometimes
I have Dude statistics on if you need them, or configs, just tell me if you need to look at them.
How are you connected to the routerboard? by LAN or remotely? Which Winbox version? which ROS version?
Have seen that when remotely connected while traversing a suboptimal connection towards the routerboard.
Some winbox/ROS versions exhibited this cosmetic issue too.
What does your dude say? Do you spot the same haircomb patterns?
Answers between lines
My Dude gives me this
But i’ve seen the dude first show it like that and then it “fixes” it? It doesn’t stay that way after some time.
Looks like micro-cuts or packet loss… try to recall back which changes or incidents took place by the date it started showing this behaviour.
