Traffic mangle in JUMP chain
Hello, I have a problem with traffic mangle when I use JUMP for splitting rules for subnets.
Rules:
chain= prerouting action=jump jump-target=test src-address-list=x.x.x.x/24
chain=test action=mark-connection new-connection-mark=user-con passthrough=yes src-address=x.x.x.x
chain=test action=mark-packet new-packet-mark=user passthrough=yes connection-mark=user-con
Then I want to use QT. But this is not work. Down direction is not limited. When I move rules form “test” chain to “prerouting”, everything works fine.
Do anybody have some experience with this?
Thanks fo reply
when in ‘test’ chain, do counters increase on your rules? i don’t think, that ‘src-address-list=x.x.x.x/24’ is right. maybe ‘src-address=x.x.x.x/24’?
Yes, you are right. It was my mistake in write. Sure it have to be src-addres=x.x.x.x/x or src-address-list=test.list
Counters are increasing, but traffic is not limited in down direction. If you have MK box, you can try it yourself.
