Hi all,
So I setup on my mikrotik RB750GR3 router the settings from the link below:
https://wiki.mikrotik.com/wiki/Manual:Tools/Traffic_Monitor
but when I test to see if it will disable or enable, it doesn’t work. Is there a specific thing you are supposed to do for it to work?
I plugged in my laptop to the port (say ether3) and to check if it would enable, I manually disabled it, plugged it in and nothing happened.
Any suggestions?
