Traffic monitor with Telegram report
Hello.
Recently we needed a script to report if an interface was passing more than X traffic.
Everything was OK if using the traffic-monitor… but with just 1 second of traffic (traffic peak) I got notified.
So, I’ve created a script that is triggered by the traffic-monitor to start the analysis.
If its conditions get accomplished, will report to some Telegram account.
And I decided to share it. So, those who need something like this, would be able to use it easily.
Example will consider:
  • ether1-wan as interface
    WAN as the interface alias
    100Mbps as the traffic limit
    90 seconds as the limit for continuous traffic and report
    10 minutes between one report and another (if traffic continues)
    wan-monitor as trigger name (traffic-monitor)
    monitor-ether1 as script name
This script was made to check the download traffic (which means RX)
You will need to create a traffic-monitor like this:
This will act like a trigger to the script to run
/tool traffic-monitor
add interface=ether1-wan name=wan-monitor on-event=monitor-ether1 traffic=received threshold=100M
And now, create a script inside /system script matching the name you have chosen
With this code inside it (replace variables as you need)
# ------------------- header -------------------------------------------
# Traffic analysis script and report by Telegram
# By Andre Almeida
# Tested in RouterOS 6.40.3
# Created at 23/10/2017
# Please, keep this header if using this script. Thanks
# ------------------- end header ---------------------------------------
#      D E F I N E   H E R E    Y O U R   V A R I A B L E S
# Interface name to monitor
:local intmon "ether1-wan";
# A friendly name to the interface above
:local ifalias "WAN";
# The limit in Mbps for the traffic
:local limittraffic "100";
# The time limit in seconds to consider continuous traffic and report
:local limittime "90";
# Define the interval between reports in minutes
:local reportinterval "10";
# Trigger name created inside /tool traffic-monitor
:local triggers "wan-monitor";
# ChatID from telegram that is going to receive reports
:local chat "0123456789";
# API code from Telegram BOT
:local bot "01234567:AbcdEfGhijklmnOPQrstuvXWY-z";
#         S T O P    E D I T I N G    H E R E
# Disabling the TRIGGER
/tool traffic-monitor set [find name="$triggers"] disabled=yes;
#Traffic analysis script starts now
#Reseting counter
:local counter 0;
:local recbits;
#Checking traffic
:set $recbits ([/interface monitor-traffic [find name="$intmon"] as-value once]->"rx-bits-per-second");
:while ($recbits > ($limittraffic * 1000000)) do={
	:while ($counter < $limittime) do={
		# Checking traffic
		# Checking if traffic is high
		:if ($recbits > ($limittraffic * 1000000)) do={
			:set $counter ( $counter + 1);
			:delay 1s;} else={
				:set $counter ($limittime + 10);
	}; #  <--- End of second while condition
	# Rechecking traffic
	# Checking counter
	:if ($counter < ($limittime + 10)) do={
		# Reseting counter
		:set $counter 0;
		# Send message to telegram if counter is acomplished
		# DO NOT REPLACE ANYTHING HERE
		# Defining message
		:local initel "https://api.telegram.org/bot";
		:local endtel "&text=";
		:local newline "%0D%0A";
		:local who "$[/system identity get name]";
		:local datetime "$[/system clock get date] $[/system clock get time]";
		:local message "Interface $ifalias surpassed $newline $limittraffic Mbps by $limittime \
		seconds$newline Actual traffic $($recbits / 1000000)Mbps";
		:local messagefinal " $who REPORT$newline $newline $message $newline $newline $datetime \
		$newline $newline If traffic persist a new report will be send within \
		$reportinterval minutes";
		/tool fetch url="$initel$bot/sendMessage\?chat_id=$chat$endtel$messagefinal" keep-result=no;
		:log warning "Interface $ifalias surpassed $limittraffic Mbps by $limittime seconds \
		-- Actual traffic is em $($recbits / 1000000)Mbps";
		:delay ((($reportinterval * 60) - $limittime) . s);
	}; # <--- End of checking counter
}; #  <--- End of first while condition
# ENABLING TRIGGER AGAIN
/tool traffic-monitor set [find name="$triggers"] disabled=no;
#                      T H E     E N D
For each interface that you need to monitor, please, rename the trigger name to be unique. And replace inside the script.
Reports will reach you telegram account (defined in chat ID) like this:
Can the script be eligible to go to the wiki?
Is it possible to use this script with a proxy?
In the light of recent events in the Russian Federation, access to the portal api.telegram.org is limited, so many important alerts stopped working.
In this regard, I would like to clarify whether it is possible to modify the script to work through a proxy.
For example:
/ tool fetch url = “https://api.telegram.org/bot***” via “socks5.proxy.server:1050”
There is one problem, in this configuration, the script does NOT include back triggers. It is necessary or in scheduller automatically to include triggers in 2-3 minutes or to add in a script a parameter about inclusion of the trigger on number
Sorry, I did not understand.
Could you explain a little better what is missing?
Thank you
Hi, is this script works on latest ros? I can’t run it and get no warnings
Yes it works.
I have working on 6.40.8 bugfix
hi, nice script and thaks for sharing
btw can we modified the script to detect the pps and send alert?
for example let say there is 75kpps on the specified interface and then notification on telegram
it might be useful to detect possible ddos traffic
thanks and regards
Reza
@ploquets
You can remove the ; at the end of all script lines.
Its not needed anymore. Only when having more than one command at the same line.
I guess you can do this with firewall rules, to match api.telegram.org and redirect thru a proxy server… not necessarily you will need to inform the proxy server directly from the CLI.
Thank you for the script
can it be altered to use mail ? to ship it directory in a support desk
I guess you can use this
# Traffic analysis script and report by E-mail
# By Andre Almeida
# Tested in RouterOS 6.45.8
# Created at 04/03/2020
# E-mail where reports will be sent
# please configure correctly your /tool e-mail
# See https://wiki.mikrotik.com/wiki/Manual:Tools/email
:local emailtoreport "test@example.com";
#Reseting counter
:local counter 0;
:local recbits;
#Checking traffic
		# Checking traffic
			:delay 1s;} else={
	# Checking counter
		# Reseting counter
		:set $counter 0;
		# Send message to e-mail if counter is acomplished
		# Defining message
		/tool e-mail send to=$emailtoreport subject="Traffic Report by $who" body="\
		******   $who REPORTS   ******\r\n\
		Interface $ifalias surpassed \r\n\r\n\
		$limittraffic Mbps by $limittime seconds\r\n\r\n\
		Actual traffic $($recbits / 1000000)Mbps \r\n\
		\r\n\r\n\
		Email sent at $datetime"
#                      T H E     E N D
can it be used in the opposite?
if traffic drops on interface below 1mb for lets say 30 seconds.. to send telegram notification?
