I see the strange behavior of the router. some time after the restart at the port which is not slave, not in included to bridge and no link we can see traffic, pls see attached screenshot. after that we have can seen other strange problems (example: dhcp client can not get ip from ether2).
uptime: 1d21h43m
version: 6.34.2 (stable)
build-time: Feb/18/2016 06:31:18
free-memory: 5.6MiB
total-memory: 32.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 400MHz
cpu-load: 14%
free-hdd-space: 48.5MiB
total-hdd-space: 64.0MiB
write-sect-since-reboot: 314136
write-sect-total: 3252589
bad-blocks: 0%
architecture-name: mipsbe
board-name: RB750
platform: MikroTik
/interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 ether4 br-lan 0x80 10 none
1 ether5 br-lan 0x80 10 none
2 D ovpn-cam bridge-vpn 0x80 10 none
/interface ethernet monitor ether3
status: no-link
auto-negotiation: done
advertising: 10M-half,10M-full,100M-half,100M-full
link-partner-advertising:
/interface monitor-traffic ether3
rx-packets-per-second: 1 196
rx-bits-per-second: 12.6Mbps
fp-rx-packets-per-second: 0
fp-rx-bits-per-second: 0bps
rx-drops-per-second: 0
rx-errors-per-second: 0
tx-packets-per-second: 670
tx-bits-per-second: 382.5kbps
fp-tx-packets-per-second: 0
fp-tx-bits-per-second: 0bps
tx-drops-per-second: 0
tx-errors-per-second: 0
