I try to setup a Traffic Shaper with a Transparent Bridge, but so far cannot get the Traffic Shaper working.
Got a MikroTik RouterBoard home Access Point lite (hAP lite).
Configuration with Winbox based on default config
IP > Address, change the default 192.168.88.0 entry to a fixed ip in my LAN (so that i can manage the device)
IP > DHCP Client, delete the entry
IP > DHCP Server, delete the entry
IP > Interface, go to ether1, set master port to ether2-master
IP > Firewall > NAT, delete the masquerade rule for ether1
Now i do have a working bridge, at least for ports 2-4. Connected ether2 to my FritzBox and ether4 to my Clients.
Traffic flows through the bridge, the hAP lite is manageable via the fixed ip.
Configuration for Traffic Shaping
Configure bridge1 to use ip firewall so that packet marking works
/interface bridge settings
set use-ip-firewall=yes
Tried to limit traffic from/to 2 ip addresses with simple queue
/queue simple
add max-limit=512k/5M name=“Limit1” target=192.168.2.101/32
add max-limit=512k/5M name=“Limit2” target=192.168.2.102/32
This has no effect.
Now my questions
Does this simple queue setup prevent all bursts? I don’t want to have any bursts allowed.
Is it possible to use Simple Queues in such a setup? What is wrong with my approach?
If i need to use Queue Trees, can somebody post a short config example how to limit traffic for a single ip with them?
Wrong. Now you have a working switch, not bridge. The traffic is fully handled by the switch chip (but not the CPU of your hAP lite) and cannot be shaped. You seem to have a bridge from the default configuration, so the only traffic that flows through the bridge and can be shaped is the traffic from/to your WiFi clients.
You need to set the master-port=none on your ether1, then add ether1 to the bridge, then also connect your Fritz! to ether1.
Thanks, i will try this out.
Do i understand it right that with this setup i will still have switching by the switch chip between ports 2-4 and transparent firewalling and traffic shaping between port 1 and the remaining connections?
And do i need to cleanup any or even all of the default firewall filter rules? As i do not need firewall rules, but only the traffic shaping i think i should try to remove all the rules.
The traffic between ether1, wireless and the rest of the wired ports will be bridged, i.e. handled by the OS. How that traffic is handled depends on the configuration. For instance it can be filtered (firewalled) and/or shaped.
They have no effect on the traffic only being bridged (but not routed), but you can of course remove all the extra rules to keep your config nice and clean.
After removing the packet-marks=“” it started to work. This was a leftover from my look into the Advanced Tab which i did not recognize in the WinBox Gui …
