This is strange. I have a firewall filter rule (FORWARD chain) on a Mikrotik router that drops invalid packets. For some reason, it’s dropping packets that are to/from the same interface, my LAN subnet. Lots of packets are hitting the rule and being dropped. Here’s an example of what I see when I log the drop rule:
forward: in:bridge1 out:bridge1, src-mac 70:88:c2:da:51:61, proto TCP (ACK), 192.168.90.51:50138->192.168.90.11:49677, len 40
Why would that traffic even hit the forward chain if it’s to/from the same interface/subnet?
Another possibility is DST-NAT (the variant called hairpin NAT).
Or proxy ARP (not likely though).
Or misconfigured client machine (perhaps wrong subnet mask) sending packets via gateway when it could deliver them directly …
Or if there’s routing triangle… in a network there are two routers, one serving as default gateway, the other only as gateway towards some specific network. Devices are unaware of the other router and send packets to first router. First router resends them to second router (using same interface for input and output … but packets transverse L3 part of router). On the way back, the other router delivers replies directly to LAN devices bypassing first router and thus screwing its connection state table.
And I’m sure there are other reasons for them, but it’s hard to think of them without knowing physical and logical network topology as well as configuration of relevant network elements …
Very interesting…I DO have proxy-arp set on the bridge interface because we use OpenVPN and enabling proxy-arp on the bridge is the only way I know of to allow VPN users to pass traffic to resources on our local network. I guess now that I know this is what was causing it I can adjust my firewall rules appropriately…but is there a better practice instead of enabling proxy-arp for my OpenVPN users?
The best is to move your VPN users to a separate subnet so it can be cleanly routed instead of using proxy-arp. Of course it can cause some issues with systems having improper routes or relying on broadcasting.
Otherwise, you can setup a bridge filter that drops the ARP requests that are not for the router itself or the address(es) used for VPN.
Then it will not reply to those, and the real device can answer and the traffic will no longer be via the router.
