I learn to configure mikrotik recently. and i find i missunderstood something about ethernet switching in RB750 RouterOS.
I configure my mikrotik RB750 ethernet interfaces like this:
lan0 192.168.10.1/24 master-port=none
lan1 192.168.11.1/24 master-port=none
lan2 192.168.12.1/24 master-port=none
lan3 192.168.13.1/24 master-port=none
lan4 192.168.14.1/24 master-port=none
The route of each interfaces shown in /ip route print as Dynamic Active and Connected.
The problem is i can’t ping each others if each interfaces using “master-port=none”, but It can if I use “master-port=lan0”, and lan1 thru lan4 marked as SLAVE, but… I got icmp redirect-Host, which meant all the network is on the same interfaces.
I hope somebody could en-light me here
