I installed 5.11.
If you try to change the cache size (for TrafficFlow) - traffic flow stops working forever.
Reboot - does not help.
I upgrade from 5.8 to 5.11.
Downgrade - does not help.
(bug probably “migrate” in Mikrotik*.backup file ?)
P.S. On some servers - ver 5.11 - behaves unstable (Kernel Panic), but 5.8 - work fine too long time…
Do you work TrafficFlow in 5.11 build - if you try to change the cache size?
Try do it …
I have the same problem with 5.11 on ESXi host: after reboot, TrafficFlow is not working (zero active flows), after disabling TrafficFlow, RouterOS prints “kernel BUG” with “NULL pointer dereference at 00000004” message on screen (no messages in Log, Terminal, no autosupout…)
