Transfer configuration between identical hardware
Is it okay to transfer the configuration backup between identical hardware? All devices are on the same software version. Just a bit worried that MAC addresses are in software and we’d end up with devices with the same MAC addresses which would be bad news :wink:
Although answering my own question, possibly not a good idea as I can see lines like this:
set [ find default-name=ether1 ] mac-address=48:8F:5A:60:9B:78
set [ find default-name=ether2 ] mac-address=48:8F:5A:60:9B:79
set [ find default-name=ether3 ] mac-address=48:8F:5A:60:9B:7A
set [ find default-name=ether4 ] mac-address=48:8F:5A:60:9B:7B
set [ find default-name=ether5 ] mac-address=48:8F:5A:60:9B:7C
Just use /export and import on other devices.
And yes, you should remove unwanted MAC addresses from exported configuration.
And Wi-Fi interfaces aren’t right… I guess the right answer here is to /export, reset without configuration and bring run exported script?
