I am not sure if this is possible or not but I am trying to do the following.
I have a file on an ftp server that has scripts in it. I want the mikrotik to download this file and then execute the scripts within the file.
Write a script that uses “/tool fetch” to download the file (http://wiki.mikrotik.com/wiki/Manual:Tools/Fetch) and set a known file name via the dst-path parameter, and then as a next step runs “/import file-name=nameOfFileYouJustfetched”.
Also, just FYI, if you upload (via push, not a download triggered by the OS) a file named whatever.auto.rsc it will get executed once you have uploaded it. Just in case that method works better for you.
better use auto.rsc feature - using ftp you can upload file called .auto.rsc
script file will be automatically executed and log file for that will be saved on the router.
It might be worth noting that the script does not execute immediately upon upload.
It executes when the ftp connection is closed. A not so subtle detail.
This might be important if you are expecting something to happen and you leave the connection open…like I was and I did.
This is a useful feature. And a great way to push changes.
We are uploading the auto.rsc scripts via ftp … but very often the file is not executed, instead of that the log shows “ppp script error: input does not match any value of file-name”
If we upload it again it is executed.. someone else having this problem also?
what settings are you trying to push? maybe there is some problem with ppp interface missing/appearing?
Janis, the interesting thing is that it doesnt matter what script we upload… even when i upload a script that only does “/system reset-configuration” it shows that error.
Yes, I also have this problem, posted problem here: http://forum.mikrotik.com/t/fetch-upload-auto-rsc-between-routers-not-executing/56819/1
what i do is…
- a scheduler (24 hours interval)to fetch the file (command to run) from the server call xxx.txt, then…
- delay 5s
- translate the file content to the “system script” like call “auto-run”, then
- delay 5s
- run the “auto-run” and once complete it will delete the “auto-run”
whatever new thing to add or new command to run, all the routerboard with this scheduler will auto update when it meet the scheduler time.
I use this file to roll out CPE changes (not ROS upgrades).
:global ftpserver
:global usrnme
:global passwd
:global pckgname
:set pckgname ("upgrade.rsc")
:set ftpserver "10.254.253.254"
:set usrnme "admin"
:set passwd "abcxyz123"
:if ([:len [/file find name="upgrade"]] = 0) do={:log error "Downloading Upgrade File - $pckgname";/tool fetch address="$ftpserver" src-path="$pckgname" user="$usrnme" password="$passwd" mode=ftp;/import upgrade.rsc} else={:log error "No Upgrade File Found";}
This script can be called by a scheduler, or a netwatch routine that looks for an IP that we turn on and off when we want to trigger the script.
Regards
Brian
Zimbabwe
how can i set ftp server path = 192.168.88.1/disk1
