Transfer my Asus router to mikrotik
Hi!
I have my PPPOE& i believe is a 20 VLAN. I have my image attached. Hope someone could help me out. =D Im using a MikroTik MikroTik hAP ax2
Assume pppoe is coming on vlan20
add vlan20-ISP as an interface, with parent interface=ether1 ( assuming ether1 is assigned to ISP cable connection ).
In pppp settings ADD + pppoe client
Here add pppoe to the interface vlan20-ISP and simply keep the defaut name think its pppoe-out1.
Done.
In the ppoe settings usually easiest to accept add defaut route as well, but I tend to prefer external DNS so dont need peer dns.
Ensure in the WAN interface list you add
I have 2 screenshot of asus. i think i got ping with 8.8.8.8 with the terminal on mikrotik but it seem lan network & wifi not running on it.
Great! i got some good news. i did a ping on the terminal like google 8.8.8.8. seems good so far. Now the second problem is how do i setup port 2 to 5 to have internet and both wifi =S ( sorry newbie on mikrotik) i have attached what i have done so far.
Okay here we go a next step! =D somehow the wifi have internet but ethernet cable not… no idea why… but in terminal show tha thave internet. (image attachedd)
Can you export your configuration ?
Go to terminal then enter export file=anynameyouwant, then in files you can find that new file is created, download it to PC, open in notepad or word editor of your choice and remove any serial number, passwords, usernames etc and copy configuration here using code function on fourm.
That way you will get help much quicker.
Okay seem somehow i need to reset there router like 5 times to make it everything run smooth ( Really Thankful) So here i left the code anyway. if there anythingi could update it !
# 2023-10-11 06:11:57 by RouterOS 7.11.2
# software id = TPV3-ECV8
# model = C52iG-5HaxD2HaxD
# serial number =
add admin-mac=48:A9:8A:CC:DE:5B auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz configuration.mode=ap .ssid="XXXXX" \
    disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40mhz configuration.mode=ap .ssid="XXXXX" \
/interface vlan
add interface=ether1 name=vlan1 vlan-id=20
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan1 name=pppoe-out1 \
    use-peer-dns=yes user=XXXXX
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/interface detect-internet
set detect-interface-list=all
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
    192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=America/Panama
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.google.com
/system package update
set channel=development
/tool mac-server
/tool mac-server mac-winbox
So now everything is working now ? Because this is pretty much default configuration and there shouldn’t be any problems.
Everything look good so far. Thanks a lots!
