Is it possible to transfer settings from one routerOS to another same version?
Can it be possible restrict user by their usage (data transfer)?
/export file=something.rsc
then /import file=something.rsc at the other new router.
Some settings will not work if its not the same kine of hardware. Then just edit the rsc, to fit your new hardware.
its also possible to to a backup. Then both system has to be exsactly the same.
Thanks.
Can it be possible to restrict user by their usage (data transfer)?
