Hi guys,
I have one level 5 license installed on some P4 Celeron 2600 with 80GB harddisk, now I want to upgrade this PC to something better with 400GB HD and P4 3200… is it possible to transfer the license key? how can I do that?
thanks
Hi guys,
thanks
You can’t transfer the key from one HDD to another. Contact MT Support, I believe they charge something like $10 to move the license - I may be wrong on the cost.
As far as I know, Mtik key is bounded to the HDD.
So, change your hardware, but keep the disk. You can add another one (for cache, or something else you want to store). This is the easyest way ![]()
