Transfer the Mikrotik license from one pc or hard disk to another one
Is it possible to transfer the Mikrotik license from one pc or hard disk to another one?
No, unless it’s a CHR.
I found an information about this topic in: https://help.mikrotik.com/docs/display/ROS/RouterOS+license+key
Below the rules:
Replacement Key
It is a special key which is issued by the MikroTik support team if you accidentally lose the license on a x86 instance running RouterOS, and the Mikrotik Support employee decides that it is not directly your fault. It costs 10$ and has the same features as the key that you lost.
Note that before issuing such key, Mikrotik Support can ask you to prove that the old drive has failed, in some cases, this means sending us the dead drive.
There is a difference between “move” & “recovery” procedure.
Licence is bound to HDD so you can move this HDD to the new PC and the ROS will start.
@zhup
[ color=#FFFFFF].[/color ]
Why you continue uselessly to add white dot on forum?
You want replace it later with spam link?
Stop that behaviour.
